Thats interesting,
LOL, back to the drawing board!
sure you know Mike but i just want to be clear, port A is teed to middle of tank and the capped extention on top which i presume you have labled port C
The 28mm to 22mm pipes after opening up the hole more for a better view are on top of each other going through the chimney breast, 3 test done, with programmer set to HW only, 3pv to HW the bottom 28mm pipe through the chimney and the pipe to pump gets hot before pipe out of bottom of tank, same result with prog HW&CH, 3pv HW or Mid
1. What is the insulated pipe coming from the top of the motorized valve (the one with a red gate valve) connected to?
for the record, 3pv valve or diverter valve you may call it, has 3 ports, port A is usually the middle port and branches off to two other ports, Port B and port C, depending how you install it, but in principle, the 3pv works by connecting port A with either port B or with port C, or in its mid position it would allow both ports connected to port A.
Sticking to a typical installaition standard helps engineers find faults quickly.
Sorry my mistake, top port B to cyl and bottom port A to heating, the only switch i could find which appeared to switch off the pump is on the pump
Mike, The OP has a Danfoss HSA3 mid position valve (as mentioned earlier in the thread!) - The middle port is AB, the CH port is A and the HW is port B in the manufacturers instructions and on the product itself.
Hmm... yes, sometimes but in this case specific detailed information is what's required, not general standards.
OP, can you confirm if the pump was on or off (electrically) when you performed DIA's test please, this is important info!
but it was unmistakable that the one to tank was hottest. Do you want me to run the test again to see which gets hot 1st?
