Hi all - I have a Ryobi chainsaw which will start but only run for a couple of seconds. The only adjustable part I can see is an idle screw - not sure where this should be. Plug looks clean, fuel correct ratio. Any thoughts?
I did change the idle screw a number of times to try to get it to work. The air filter is grotty but you can see light through it well. Thanks for reply - any further thoughts appreciated.
