Changing flue from top to back of wood burning stove
21 Jan 2013
Fife
Ive had my stove for a couple of years and it's set back into the fireplace recess with a plate to stop the draughts. I bought an elbow so I can bring the stove into the room a bit to give me more heat but I can't get the back screws loose to get the back plate off. Is this because they have attached themselves due to the heat or am I doing something wrong. I'm a small female so perhaps just don't have the strength to turn the screws?? Please help. Thanks.
There is a possibility that the screws are actually nuts and bolts, so do check that first.....failing that its a big screwdriver and plenty of muscle, I'm afraid - together with copious sprays of WD40 or similar.
I doubt whether the extra few inches of projection into the room would make any difference really - assuming your stove flue passes through a register plate which effectively blocks the chimney off.
Have you considered an 'eco fan'?
John :)
HI,
I am a Hetas registered stove fitter.
Firstly, you should not be doing this job yourself unless you are doing it under Building Control guidance or are registered as a competent person under an official scheme e.g. Hetas.
You can only come off the back of a stove with a purpose designed 45 degree elbow (so soot falls back into the stove and does not block the stove) or a T with a soot door. A ninety degree elbow is not allowed. You may of course know all this.
Trying to dismantle bits of old stoves is often difficult if not impossible.
