Cheapest place to get swa y joint kit
So it is impossible to sell a joint that is IP68 at time of sale, it only becomes IP68 after being assembled correctly.
That is why I asked about these boxes as I would expect failure over time,
The product detail states:
PRATLEY UNDERGROUND joint boxes are quick and easy to fit with earth continuity assured by means of the unique integral gland. They are dust / waterproof, with inner seals in the glands and an 'o' ring gasket in the lid and need not be compound filled.
And then
Meets the requirements of IP 68.
The weak point with any IP rated jointing box is the cables entering the joint. Moisture migrating along the cable inside the outer sheath will get into the joint. An IP68 joint box's barriers to water ingress would be defeated if the cable sheath was damaged close the the joint and allowed water into the cable. A resin filled joint overcomes this problem.
