Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi, have just moved in to a new build house and they have fitted an AEG gas hob (built into the work top). What is the minimum clearance or gap that should be between the hob and the back wall or splash back?
tom you are better off asking in the plumbing section but i suspect the answer is in the manufacturers instruction manual,which you should have in your home pack
