I have a Gainsborough 2000x and today it triped the circuit breaker and now it wont heat the water .Is there any internal fuse or can you change the heating element .
Hi - I put a Gainsborough in for a friend last year and when the unit didn't work, the number on the box gave me a direct line to Gainsborough support. They were excellent - sent a replacement part out straight away and the job was a good-un!
Thereshouldn't be another fuse - will it still heat water? If yes then the poer is okay but the pump unit sounds like it is nackered. If you can't get power to it test the safety switch on the ceiling first, then look at checking the switch in the CU to enmsure it is not damaged!
Have fun...
if you change the unit don't go for a Gainsborough (I have wired 6 in past 3 years and 5 have deveolped a fault either straight away or within a few days).
please note this is my opinion, I really don't rate them at all.
