cold radiators...exept one
14 Jan 2008
Southampton
i've come home tonight to a cold house, all the radiators are cold except one which is in the same room airing cupboard / hot water tank. Hot water from the taps is still boiling. It was working fine this morning. if i open the airing cupboard, the pump is red hot to even touch...is that right?? it's making a noise every so often...does sound like its struggling but not sure. a few weeks ago it was quite noisy but this seemed to have stopped? any ideas?? I've read about opening up vent plug above pump..is this recommened? In one DIY book it says...slacken nipple in flow pipe from pump?? any ideas
if its that hot turn off and allow to cool b4 openning bleed screw on pump
Yes, turn off let it cool down, then vent pump. Make sure you have towels handy to catch the water that spills out of the venting screw. When you start it up again touch the pipe on the pump outlet to confirm that the pump is actually drawing hot water away from the boiler.
