think a pump would cause problems with a combiIf its simply a pressure problem you could pump it if its off a tank. How high is the tank above the boiler in metres?
Nothing wrong with using a tank if you get the right pressure.
My money is on a blockage in or to your boiler
no it won't
no it won't
pray do enlighten me![]()
The boiler never reads more than 1 bar of pressure, my British Gas engineer says 1 bar is enough pressure to supply the boiler. Everytime I turn on the hot water tap very little sometimes no water comes out.
