Conduit bends in wall
22 Jan 2012
UK
I am doing some chasing out work soon to add some electrics in a bedroom.
This will be the first time where I have not had access to the ceiling space to route cable via. I will be going from a FCU down to a flex outlet for a heater. They are not directly above each other though, so a bend will be required.
I usually use 20mm oval conduit, but there don't seem to be bends available for this. I could use 20mm round conduit with bends, but this will mean channeling deeper.
Are there any other good solutions?
Thanks!
Are you planning on it having to be rewired anytime soon. If not just use some capping by cutting some 45's to form a 90 ?
No rewire planned, the electrics aren't very old so its just an addition.
I guess I can use capping with 2 45degree cuts... just wondered if there was a better way to do it!
It is unlikely that you will be allowed to bent the conduit it the wall.
Cables must run horizontally or vertically to an accessory.
Search for: Safe Zones
They will be. Horizontally from the FCU and vertically to the outlet (or vice versa)
Why not just mitre the two bits of 20 mm oval?
Can you imagine pushing/pulling a cable through a sharp right angled bend? It has to be gentle, like a slip bend.
Am I missing something here?
This is just regular twin and earth cable in oval conduit in plaster? With no particular attention to new wiring being pulled through in the future?
The last piece of conduit can be slid over the cable once a bend in the cable has been formed.
What is the problem here? Clearly I am misunderstanding...
OR ... just bury the cable in nice cooling masonry.
To my mind there's no point in using conduit if you can't pull the wire through. You might just as well clip the wire to the wall and plaster over if you don't want to do it properly.
