Connecting to old 1inch copper
9 Aug 2009
Blackpool
hey is it ok to connect old 1inch copper to 28mm copper via 28mm Yorkshire or end feed fittings or a 28mm compression fitting?
it will not be sloppy it will be tight 1" is slighly bigger 28mm fitting will go with a bit of force
Ive never needed to use an adaptor !
Ok, That makes sense. Looks like I've been wasting money on those metric to imperial connecters then.
No it doesn't. We're designing and installing water carrying systems. We need to be calculating using the bore of the pipe, so 1/2" 12.7mm 1" 25.4mm whatever! Whoever thought in the 60's it was a good idea to start referring to everything by outside diameter? What good's that to an engineer?
You don't see electricians ordering by the diameter of the cable, it's by the cross-sectional area of the copper. That's the most important aspect, what you require for the flow/pressure loss, whether it's water or electrons!
You got a 54mm socket former gav???? :wink:
22mm don't fit
35mm don't fit
42mm don't fit
54mm don't fit......depends on kahoonas.
15/28 will fit...... :D
So 22mm copper tube is not refered to by its outside diameter? nor 15mm? or maybe 28mm?
Imperial to metric tube came about in the early 70's , not to be confused with currency.
PMSL THAT SOMEONE CAN BE ADAMANT THAT 28 DONT FIT INCH and has been buying adaptors most people would just have tried it and seen if it fitted.
Fekin basic
