So 1 inch is bigger than 28mm is it?? Is that a metric inch, or imperial?
Try this and get back to me.
http://www.convertunits.com/from/inch/to/mm[/QUOTE]
right im getting back to you !!
this post is about pipe sizes not converting measurements
imperial pipe is measured ID metric is OD !!
1/2" and 15mm
1" and 28mm
2" and 54mm
will all fit
No it doesn't. We're designing and installing water carrying systems. We need to be calculating using the bore of the pipe, so 1/2" 12.7mm 1" 25.4mm whatever! Whoever thought in the 60's it was a good idea to start referring to everything by outside diameter? What good's that to an engineer?Ok, That makes sense.
Of course they are, that's my point!So 22mm copper tube is not refered to by its outside diameter? nor 15mm? or maybe 28mm?
You got a 54mm socket former gav????
