I would really appreciate some advice on the situation below, probably very straightforward but I don't want to mess it up..I'm a total novice when it comes to electrics!
Purchased a new gas hob to replace existing one. Existing Hob has battery powered ignition, new one needs mains supply. Instructions in new hos state' must be connected using fixed wiring via a double pole switched fused spur outlet with a fuse rating of 3amps, with contact seperation of at least 3mm in all poles'. The wire from the hob states that any plug fitted to this appliace must be rated 15amp with 3 amp fuse.
Beneath the hob is a microwave, powered from a flat plate box?? which is in turn powered from a 'cooker' switch (not fused or cant see one)above the worksurface which also containc a single socket too.
Anyway, the microwave (built in)just connects into the single box via twisting of supply wires and microwave wires. I was just going to connect the hob wires into this aswell but the supply wires are so short I cant even get the box/panel back on. ps. this isn't fused either.
The ideal solution for me would be to buy a single to double socket converter and replace the panel/box under the hob. Then fit 13amp plugs to both microwave and hob(with 3 amp fuse)and away i go.
I do have some concerns though a the hob says must be fixed wired and also if fitting plug must be 15amp rated, I haven't even heard of a 15amp plug.
Also if i need to extend the socket supply wires is it ok to used terminal blocks?
Any help appreciated.
Thanks.
Brian.
Thanks.
Brian.
