Hi, I have a new multi bulb ceiling lamp which requires assembly. That's fine but there is no provision for joining the wires together.
Is there a recommended type of block or whatever that would do the job?
I have two wires from each bulb, so 15 brown and 15 blue, that have to connect to the main brown/blue feed in the fitting, this then connects to the feed from the ceiling in the usual way. It's the amount of wires in the fitting itself that needs a connector that can accommodate 15+1 brown and 15+1 blue.
I could use a multi block but would have to jump all of the entry's for continuity to the feed, so I thought I would ask if there is something easier.
Thanks.
Thanks.
