Consumer Unit
18 Mar 2010
Lancashire
Is it straight forward changing a 8v 1a transformer on a din rail to a 12v 1.5a transformer in consumer unit
Is it the same size as the one you are replacing?
Are the connection requirements the same?
Is the existing one connected properly?
Unfortunatly the new transformer is at the post office it was delivered today while I was out, I will write tomorrow. Thank you
Why, oh why, did you start a NEW topic.????????????
It would have been much better to add the question to the topic you have already started. http://www.diynot.com/forums/viewtopic.php?p=1817150#1817150
:roll:
Hi everyone, Job done, replaced transformer from 8v 1amp to 12v 1.5 amp on consumer unit drilled 3 walls threaded bell wire from original bell chime to additional bell chime in dining room and connected. It works a treat.Thank you.
Come to that, why quote a post and then not refer to it....? Glad you are sorted.
