As above K18 42" deck. bearing seized on small front blade, successfully removed and new bearings fitted but the two larger blades cannot remove the pulleys, removed the bolts, pulleys only appeared to be a push fit with a key but I can't move them.
They are not rusted as far as I can see, have applied liberal amounts of penetrating fluid and tried levering them, solid. Used a bearing puller and only succeeded in bending the pulleys, have tried hitting the top of the shaft with a large hammer and drift and applying heat, moved a fraction but that's all.
Help!
Peter
Help!
Peter
