Six deaths in the tragic fire in Neasden last weekend reminds us of the possible consequences of an electrical fire, and why legislation such as the Plugs and Sockets Regulations is so important.
eBay has been a bit slow in reacting to reports in the past few weeks, but Amazon takes the biscuit for lack of response.
The worst example (so far) is on
http://www.amazon.co.uk/Volex-Cloverleaf-Computer-Power-Lead/dp/B0011YNM90/ . On that one listing they have 31 suppliers, I have test bought from several of these, some have been legal (including Volex ones), others not. The cables supplied through Amazon by “Star e-shop”, and “eBlink” have to be seen to be believed, this is what I found:
• Counterfeit fuse ( a very crude imitation with no approval marks, no sand filling, loose end caps)
• The fuse was cosmetic and
not connected to anything, the line wire is connected directly to the line pin
• Partially sleeved earth pin (resulting in intermittent or no connection to socket earth)
• All pins are the wrong size (and one sample has severely misaligned pins)
• The moulding of the plug/cable assembly has taken place with the fuse carrier and fuse in place, with nothing to prevent the moulding material flowing into the fuse chamber, one of the samples was almost entirely filled in this way completely sealing in one end of the fuse.
• The plug is marked: “ KING CORO”, “APProved bY BSI” and “Licence No 41231” with a counterfeit Kitemark
• The C5 connector is wired in reverse
• The flex cable is marked “CCC YF 227 IEC 53(RVV) 3x0.75mm2 300/500V GB5023.5-1997 MADE IN CHINA”
• The resistance between plug and C5 connector is unusually high, suggesting that the conductors are far smaller than the 0.75mm2 claimed – confirmed by inspection.
The actual conductor cross section is less than 10% of the rated value!
• The outer covering of the cable is so weak (approximately the consistency of liquorice) that it can be easily peeled off using the force of finger nails only.
• The colour coding of the wires is not in conformance with any known standard, the current carrying conductors are slate grey, and the earth is slate grey with a stripe of greenish white.
• The insulation on the conductors is of a similar consistency to the outer covering, very easy to pull off with the fingers.
I find it difficult to express just how bad these cables are!
Some extracts from customer reviews on the Amazon site confirm that the fire danger is very real, and has been reported to them for over one year:
“After only a couple of weeks use, the
cable started to burn and melted through while it was being used by my daughter, thankfully no harm came to her or the house!”
The cable started sparking then caught fire and burned a hole in the carpet. It was only the sound of the sparking that alerted me as I was not in the room. Very cheap but extremely dangerous. If the house had been empty this could have been a disaster. The thick cable is deceptive, it looks like good quality but the wires inside it are very thin, a bit like fuse-wire. This product should be taken off the market. I am reporting this hazard to Amazon and trading standards.”
“Cheap yes but as I type I can smell a distinct burning smell coming from my powerpack.”
After two weeks it started to spark and strong burning smell came from it. Wouldn't advise buying. Tried it once more just to make sure and
it exploded with a large bang and now has a small hole in the connector.”
