CQR Piccolo Internal Sounder
4 Oct 2019
Hi all,
I'm just wondering is it possible to wire this alarm up to a magnetic door contact and a key-switch isolator rather than wiring it up to a control panel like it is intended for?
Many thanks,
Lewis
This is the instructions manual with information about the wiring terminals
  • A4-piccolo_instructions_grade_3_issue-5 (1).pdf
What for a door alarm ? If so you will need either a relay or a normally open contact
If you mean one of those battery powered stick-on alarms, it's not good enough sadly.
We need an internal sounder wired up to door contacts and a key-switch insolator.
This is because we have children and this alarm is to let us know if someone's gone in/out of the building without us knowing.
NO ....I Was asking if you was wanting to use it as a door alarm ....
Oh sorry I did not read the message properly, yes I do.
What would I need to do in order to achieve this? Obviously an alarm (which I got) and door contacts
I'm still not sure what kind of relay I need, I got the internal sounder, the door contacts and the DC power supply, it's just a relay I'm having trouble finding.
Anyone got any suggestions?
