But isn't 99% of the improvement down to simply shortening the leads?Much nicer.
Well, yes. That's what he was commenting on, right?
Has anyone ever mentioned to you that some of your comments seem a little abrasive?
They can't, but if you've only got a limited number of standard sized cables to choose from, you can ID it by measuring the overall diameter of the conductors.You should note that the diameter of stranded cable can't be used as a reliable indicator of CSA. Round strands cannot be packed together without a gap.
So on the subject of ferrules, I've just seen these on fleabay: http://www.ebay.co.uk/itm/230973662271
They look rather interesting.
I would have thought ... if the terminal has a round hole, then hex probably conformes to the terminal shape better, and two or more hex-ferruled cables would 'fit together' within the round hole better. However, with a square hole, or a 'clamp/saddle/basket/whatever type terminal, a square ferrule would probably be theoretically better.A follow up. I have been looking for a "cheap" ferrule crimp tool for a bit now. ... Verdict, does take over a week to come but they do the job nicely, though it should be born in mind that they produce a "square" crimped end. For DIY use they appear to be perfectly adequate. The packaging suggests that there is also a hex version from the same manufacturer (it's all in Chinese), and a quick search on eBay shows ... which is a bit more expensive. Not sure what the advantage of hex over square crimping is to justify the additional expense though.
Up to a point but, given that one usually can't get too violent with the scews without them shearing off (or otherwise being damaged), I think one is probably more likely to get close to ideal 'distortion' if one starts with a ferrule of optimal shape for the situation involved.I figured that as well, but surely that applies only till the point you tighten the screw down and the ferrules shape gets distorted anyway.I would have thought ... if the terminal has a round hole, then hex probably conformes to the terminal shape better, and two or more hex-ferruled cables would 'fit together' within the round hole better. However, with a square hole, or a 'clamp/saddle/basket/whatever type terminal, a square ferrule would probably be theoretically better.
Indeed. Although I can see the pros and cons, it may make more sense for the warning to remain there ('for ever') on the basis of the original start date of the thread, even when there have been recent posts.And the red post warning disapears ,so even more people post unaware![]()
