Perhaps you should reflect on why any conductor which carries electricity is insulated.Come on...... I'm dyin' to know why a bus bar would be insulated? Not being an electition an all.
Kind Regards, John
Kind Regards, John
It depends upon the design of the particular CU but, particularly if it has no 'cover' or suchlike in front of the bus bar, there's a lot of live exposed metal there just waiting for someone to touch if they have the cover off the CU.Since buying my first house I've had the opertunity of taking my old CU to bit's and I can't see why it would need to be insulated?
Kind Regards, John
Which all CUs have - proprietary busbar designs, proprietary distance between rail and busbar, proprietary depth of breakers.....Proprietary fittings again eh?
very important for a 3 phase bar where 3 seperate bars run parralel within millimetres of each otherI'm dyin' to know why a bus bar would be insulated? Not being an electition an all.
Any tips/gotchas/whatever-you-do-don't-do...s for cutting insulated CU busbars?
I had planned to just use a hacksaw with the work clamped either side to stop the plastic cover moving about....
It's why so often you simply can't put any old breaker into a CU.
Wylex not being such a good make.:
I would.
Electrium churn out nothing but garbage from their factory these days, regardless of who it's branded as. I won't touch it with a barge pole.
Stick with hager, MEM, or schneider and you'll be fine.
You surprise me there, not doing domestic myself never really knew mem and schneider got considered much outside the commercial stuffStick with hager, MEM, or schneider and you'll be fine.
I would.
Not to mention I've just spotted a recall post on some of the MCB's. Too tired to check anything now though.
You can't see this:A bit off topic but..... any way of multi-quoting posts or do I have to code it myself? Can't for the life of me see a button for it.
They don't by DIs or electricians who have only done domestic work and only think about the default "domestic" makes like Wylex, Volex, MK, Contactum...You surprise me there, not doing domestic myself never really knew mem and schneider got considered much outside the commercial stuff
