You’d maybe like to consider a brass back nut, rather than the ghastly plastic ones normally supplied!
John
are they likely to be plastic?
Often they are, which makes full tightening almost impossible.....if Screwfix can’t supply, Toolstation can.
John
If I buy taps and the back nut is plastic, its the first bit to go in the bin.....anything more than finger tight the thread slips and the tap can move on the basin. A right PITA.
John
Umm... back nut? You mean the one which holds the tap in place... are they likely to be plastic? Seriously?
Right. But there's probably no way of me knowing if anything on the SF site has plastic or copper I guess...?
Took a while as not easy to find, but: https://www.screwfix.com/p/bsp-female-flanged-backnuts-x-2-pack/66268
