You’d maybe like to consider a brass back nut, rather than the ghastly plastic ones normally supplied!
John![]()
are they likely to be plastic?
Often they are, which makes full tightening almost impossible.....if Screwfix can’t supply, Toolstation can.
John![]()
If I buy taps and the back nut is plastic, its the first bit to go in the bin.....anything more than finger tight the thread slips and the tap can move on the basin. A right PITA.
John![]()
Umm... back nut? You mean the one which holds the tap in place... are they likely to be plastic? Seriously?
Right. But there's probably no way of me knowing if anything on the SF site has plastic or copper I guess...?
Took a while as not easy to find, but: https://www.screwfix.com/p/bsp-female-flanged-backnuts-x-2-pack/66268
