Hello, I have a situation that may resonate, I think there could be two faults:
Situation: excessive oil being used in heating/hotwater system, pump never turns off, radiators often hot even when programme is set to off/off.
There is a drayton motorised valve on a Y valve
Often one can hear a rapid clicking like a relay while the valve poistion remains pretty much in the mid position. I understand that the motor is held in mid by pulsing the motor against the internal spring however I have not hear the consent clicking before does that lead one to think motorised valve at fault or the physical valve or the programmer or the thermostat(s).
If it were not that the pump doesn't turn off i would have looked at the motorised valve as the culprit, and questioned if the actual valve is working freely or to full deflection ( there is only a very small amount of travel of the lug that engaged with the motor maybe 20 degrees max )- is this deflection normal?
The programmer has been changed recently by a heating engineer who came to do the annual service of the boiler ( waste of £50 plus labour as if anything the problem has got worse ( £500 oil used in three months)
So, all comments and suggestions very welcome, the Pump is a grundfos UPS 15-50 and there is a honywell wireless thermostat on central heating which appears to demand heat according to temperature settings so I dont think that there is a fake demand signal causing any issues, at least not from the CH, I dont know how to check the hot water stat,. the system was fitted by an animal really shoddy work the control box is an utter mess I am slowly going through the connections to at least get an idea of how it has been worked out, as this was a renovation by a very dodgy developer ever corner has been cut so I can not say even that the system was ever correct.
Happy to answer questions and receive the benefit of engineers with experience in this area, this is not my area of expertise and after three attempts of calling on local heating engineers by the SWMBO I am fed up with the head scratching lets replace a part and get out quick approach to the problem.
cheers
cheers
