I have just replaced two ceiling chandeliers with LED ones. Each has 24 bulbs @ 4W each. Both are driven from two 2-gang 3-way dimmer switches, which also drive some wall sconces (6 bulbs @4W each). So, in total each 3-way dimmer switch is driving 54 LED bulbs (all 240v), totalling around 216W. I think the dimmers the sparkies installed are overloaded, as the lights won't power on. They installed dimmers rated at 200W incandescent. The dimmers are programmable, and can be set to Modes 1, 2 or 3. I have tried all three modes, without a single bulb lighting.
So... if the problem is that the dimmers are overloaded, can anyone tell me if there are dimmers that can cope with so many bulbs? All the ones I've found are limited to 10 or 20 bulbs total, which isn't enough to drive even one of my pendant lights/chandeliers.
Is there anything else that might be going wrong?
