Hello All,
I am after a bit of help and advice.
I am currently in the process of building a loft dormer in my end of terrace Victorian property. This is my second attempt at a loft dormer after successfully completing one in a previous property some years ago. However this one is turning out to be slightly trickier..
Before starting i consulted my local building control officer who advised it was not permissible to support the RSJ for the Ridge Beam in the chimney breast as i had planned to do. After some deliberation i decided to remove the chimney stack and breast from the gable end down to the floor level of the loft so i could rebuild the inner skin to support the RSJ, thus preserving some much needed room space that would have otherwise been taken up by steels supporting the ridge.
I have got to the point where i have carefully removed all of the chimney stack and breasts down to the floor of the loft leaving the outer skin of the gable end and the header bricks in place. I now need to rebuild the inner skin and have a few questions on a few things i am unsure of...
(I should add, i am a keen DIYer who likes to tackle most things, but brickwork is something i do not have much experience with. I am trying to work out if this is something i can do myself or need to get a brickie in for)
1. The Outer skin of the gable wall leans in slightly. (Using a level the top leans in 40mm from the bottom) There is no cavity between the outer and inner skins so if i rebuild the inner skin following the outer skin it will also lean in. Is this acceptable, especially if i am going to be supporting the ridge beam RSJ from the inner skin? I am thinking probably not?
2. As i will need to cap the chimneys off with Concrete Lintels before building the inner skin. I had an idea to use 140mm Wide Lintels and starting my new wall from the edge giving me 40mm to play with to enable me to keep the wall straight going up to the top of the ridge. This would give me a 40mm cavity at the bottom, obviously narrowing to 0 as the inner skin meets the outer. Is this feasible and more importantly allowable?
3. What would be the best way to tie the inner and outer skins in? Just by using the current header bricks and building around them and cutting bricks or blocks to fit in or by using wall ties? Photos Attached
4. Would you build in the inner skin back up using the existing bricks from the chimney stack or use Dense blocks? I was thinking Blocks would be easier if doing it myself.
5. Or is none of this appropriate and i would need to get the outside and inside skins of the gable end totally rebuilt?
