I asked that.
And it is that very question of yours I was referring to.
I asked that.
That's not a reason for installing a ring in the first place.
I suppose the answer might be "You can use more appliance on a 32A ring than a 25A radial" but everyone else in the world manages without rings.And it is that very question of yours I was referring to.
Fair enough - but I don't think it is a good enough reason when it does not apply to any other circuit.Maybe not, but it was one my reasons for liking rings.
I only watched a few clips, that guy prattles on too much for meHe or she is mentioned a few times in the video
7/0.029 is larger than 2.5 mm² so when the ring final was designed, with 30 amp fuse, even if the ring final was broken the overload was a lot less, and we should not have to plan for people fiddling and getting it wrong, the loop impedance tests every years should highlight any errors.
When I used to carry out inspections, I would say dodgy rings were the single most common fault, some caused by NICEIC firms tooI agree, there are so many electrically dangerous things which amateurs can do to a installation, so why single out the ring circuit?
No, it isn't.It is, you have a fall back position, another option in case of failure. Just like carrying an empty fuel can in your car boot. I would need to be certain of the cause of the failure though..
No, it just keeps saying everything it does is.In some things, the UK is ahead of many countries.
Not really.Maybe not a good reason on it's own perhaps, but the ring circuit has many advantages.
Like sticking with ImperialIn some things, the UK is ahead of many countries.
Maybe not a good reason on it's own perhaps, but the ring circuit has many advantages. I do agree it lacks some of the advantages that it once had, so were I to be installing one now - I would be considering whether to install a ring or a radial. In a kitchen, it would certainly be a ring, with a radial for fridges and freezers.
Probably safer than 230They manage, but we manage much better with the ring on 240v. Don't forget the US has 120v and needs two phases for the larger current appliances.
