    Dismiss Notice
Dodgy socket
Discussion in 'Electrics UK' started by raebhoop, 19 Jan 2014.
  1. raebhoop
    raebhoop
    5 Aug 2009
    538
    Thanks Received:
    2
    Nottinghamshire
    Country:
    I have one single living room socket playing up...all the rest are ok.If I plug the vacuum in, it stutters on and off like a bad connection. I've not removed the socket yet for a look see,thought I'd come on here first.
    I've plugged in one of these below and am a getting the continuous tone 'correct' reading. Vacuum ok in other sockets by the way.
    Thoughts please....
    [​IMG]
  2. flameport
    flameport
    10 Mar 2007
    9,817
    Thanks Received:
    1,962
    Poole, Dorset
    Country:
    Loose wires, faulty socket or both.
    Likely the fault only shows up when a decent load is connected, so that rather useless testing device will show as working.
    Replace the socket.
  3. Sponsored Links
  4. EFLImpudence
    EFLImpudence
    7 Jul 2010
    37,082
    Thanks Received:
    4,160
    Retired to:
    Country:
    Portugal
    Probably a loose connection in the socket or vacuum plug showing with the relatively high current required by the vacuum..
    If all wiring connections are satisfactory then I would suspect the 'prongs' in the socket or socket switch contacts so just replace it.
  5. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    As above it is very likely to be one of those faults, loose or damage conductor behind socket or the socket contacts are starting to fail.
    So to remedy this, you would need to identify circuit, prove it is dead,socket tester may come in handy there!
    It would also be wise after removing covers testing again with an approved voltage tester if you have loose conductors/faulty contacts.
    Once that has been done, check for loose/damaged cables, if none then a socket replacement would be the next step.
    If still having intermittent power loss after the above you may have a loose/damaged connection in nearby socket/accessory that could also causing this power loss.
  6. Sponsored Links
  7. raebhoop
    raebhoop
    5 Aug 2009
    538
    Thanks Received:
    2
    Nottinghamshire
    Country:
    Much obliged...
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
