Radiators used to be sized to room temperatures, 16⁰C in a hall or bedroom,18 kitchen and bathroom, 21 living dining rooms when the flow temp was set to give a 75⁰C flow and a 10 or 12⁰C ∆T.
I remember trying to do that, my second house, which was built around 1980 and had just a gas fire for whole house, and open plan, and the bedrooms ended up far too hot. Lucky the TRV had been invented.
Today, I am looking at heating only one room to 22°C the rest of the house can remain much cooler, and this is resulting in a problem in Autumn and Spring. Basic fact is my central heating boiler does not like only heating one room.
Winter OK all rooms heated, rest may be at a lower temperature, but all rooms have some heat. But if I only want to heat the living room, it does not take much intelligence to work out, the living room must be one of the rooms with a boiler firing thermostat. Can have boiler firing thermostats in other rooms as well, but one has to be in the living room.
So I know with my Drayton Wiser I can have one hub and many wall thermostats, I seem to remember up to nine, but with Nest Gen 3 I could only have one, which is why Nest never really worked for me.
As to which control systems allow multi-thermostats I don't know, with my first house, the hot air system pumped air around the house, into rooms through vents mainly in the floor, and back through vents in the doors, so the whole house was heated very fast, and with one thermostat, and since USA uses hot air systems, there are thermostat systems made which are designed to have a single thermostat.
But in the main in the UK our doors don't have vents in them, and we can select which rooms are heated. So buying a USA central heating instruction manual does not work in the UK.
I looked at early Hive, and it said if the main thermostat shows 22°C or more, it will not accept demands for heat from other rooms, that may have now changed, but as a 75 year old, that was no good for me.
