Don't use Slotted Screws......
Yep Done that though I was fitting some ornate, expensive door handles.. the driver slipped and I managed to gouge the base of the handle...
AND stabbed my thumb :(
One little tip that may help you all, after drilling the pilot hole use a pozi drive headed steel screw first - then put in the cosmetic brass screw. Once a thread has been cut in the timber the screw will drive in much easier.
Also, does anyone else just throw away the screws supplied with most accessories? I always do now if I can due to the abysmal quality of the screws supplied! I had one too many screw snap on me... :roll:
Now why didn't I think of that. s'obvious eh?:oops:
Have done for years. I used to have arguments with the wife about this point. She was under the impression that the fittings, supplied with the item must SURELY be the ideal for the application.
The final clincher was when we bought a 5ft wide venitian blind. It was supplied with just four 3/4 inch No 6 screws, with the weeniest little rawplugs that you ever did see. Even the she didn't believe that, they were seriously expected to hold the thing up. Perhaps we should keep a record of the most "optimistic" cases.
IKEA don't even supply screws and plugs for some of their wall hanging "furniture" as it states that the fixing required is dependent on the wall. Very true no doubt, but I bet that gets some folk in a right old pickle :D
I bought some pozi head screws from my local timber merchants at the weekend, I asked the mature chap behind the counter what ones he recommended as I wanted to use my powerdriver. I was doing a lot of boxing in and fixing. some of the screws I had to take back out as I hadn't secured the boxing correctly and they were fine. I don't know what they wre made from but they were brass coloured and double slotted. Apparently most of the carpenters have started using these as they are designed for use with powerdrivers when not using a pilot hole
I find that most "things that need to be screwed to the wall" work rather well with no. 8 screws.
You guys are probably like me, you want to make sure the bu**er stays up.
Frame fixings are wonderful things too: I've got a dozen big 'uns holding my bedframe in place, never creaked or skidded across the floor in 3 years. Grrrrreat! :wink:
david and julie said:
I know your single Adam but three years! :cry:
Hey, I've tested my workmanship thoroughly I'll have you know! If it wasn't for those frame fixings the bed would fall apart from all the notches cut into it :lol:
________________
moderator
post locked to prevent hijacking
