i have a new used extiorer front door that is to small for existing frame. i do not want to replace frame (budget). new door is 5.5cm to short in width & 6cm to short in height. any advice would be great.
I am being serious, its of no use to you, because if you had carpentry skills to extend it properly, you wouldn't be asking here what to do with it. It is going to cause you a lot of grief either way, be it you (or some one you employ) extend the door, or make door frame smaller, it will cost more than a new door the correct size would be
