door frame
21 Jul 2004
i have a new used extiorer front door that is to small for existing frame. i do not want to replace frame (budget). new door is 5.5cm to short in width & 6cm to short in height. any advice would be great. :shock:
sell the door
I am being serious, its of no use to you, because if you had carpentry skills to extend it properly, you wouldn't be asking here what to do with it. It is going to cause you a lot of grief either way, be it you (or some one you employ) extend the door, or make door frame smaller, it will cost more than a new door the correct size would be
Can you not put another door frame inside it ? bearing in mind the ideal door height should be 6' 6"
it can de done
padding out the frame or door
but if you do it wrong not only does it look complete poo
you can seriously affect the security of your propperty
hello mr insurance man what do you mean im not insured
if you pad out the frame because its a all in one frame
[for security] you will have to router a piece of wood to
fit in the rebate with an equivilent rebate on the new edge
sounding a bit complicated
no its quite easy if you know how and with the right tools
good luck
:D :D :D
big all
