    Dismiss Notice
Draught around boiler flue through tiles
Discussion in 'Plumbing and Central Heating' started by AdFromEssex, 26 Oct 2019.
  1. AdFromEssex
    AdFromEssex
    17 Jan 2012
    20
    Thanks Received:
    Essex
    Country:
    Hello all,
    Is there anything I can do myself to stop draughts coming in around the flue of my boiler, as pictured?
    Aside from covering the cupboard in silt and occasionally blowing the door open, the draught hasn’t caused any major problems. It’s more of an annoyance.
    If it’s best left as is, please say.
    Cheers,
    Adam
  2. Sponsored Links
  3. AdFromEssex
    AdFromEssex
    17 Jan 2012
    20
    Thanks Received:
    Essex
    Country:
  4. AdFromEssex
    AdFromEssex
    17 Jan 2012
    20
    Thanks Received:
    Essex
    Country:
    PS photos taken at dusk, hence no daylight showing through the gap.
  5. CBW
    CBW
    26 Sep 2019
    9,060
    Thanks Received:
    2,422
    North
    Country:
    If you have a gap it may be the lead part of the terminal slate. You may need a roofer or gas engineer with roof ladders. That’s quite a big gap in the felt/membrane.
    • Thanks Thanks x 1
  6. just pumps
    just pumps
    24 May 2016
    2,984
    Thanks Received:
    507
    Country:
    As above really, as the pipe doesn`t get hot stuff an old towel in the gaps inside to stop the draught.
    • Thanks Thanks x 2
  7. dilalio
    dilalio
    20 Mar 2009
    7,934
    Thanks Received:
    1,292
    Potters Bar
    Country:
    Expanding foam.
    • Thanks Thanks x 2
  8. Nige F
    Nige F
    28 Jun 2005
    21,206
    Thanks Received:
    1,741
    Country:
    Go with dilalio - and before you get sqiuirting , form a large cup shape with plastic dust sheet tacked to the roof joists - the foam is good stuff but it tends to fall onto things (your boiler) below as it expands.
    • Thanks Thanks x 1
  9. dilalio
    dilalio
    20 Mar 2009
    7,934
    Thanks Received:
    1,292
    Potters Bar
    Country:
    Do it in stages if necessary. You don't want a big blob of it dropping onto you or your boiler... I've had it in my hair before... Not fun... If it does spill, wait until dry before trying to clear it up.
    • Thanks Thanks x 1
    • Like Like x 1
  10. Sponsored Links
  11. just pumps
    just pumps
    24 May 2016
    2,984
    Thanks Received:
    507
    Country:
    Oops, meant that as a temp measure, a make do for now not forever.
    • Thanks Thanks x 1
  12. Madrab
    Madrab
    4 Oct 2012
    8,244
    Thanks Received:
    2,356
    East Renfrewshire
    Country:
    I'd be more tempted to seal that back up with a similar felt or waterproof material that can be attached and sealed to the existing using a rubberised/bitumen high adhesive tape.
    not taking away from expanding foam but I find it's awful stuff and it could lift the tiles if it gets under them too far.
    • Thanks Thanks x 1
    • Like Like x 1
  13. dilalio
    dilalio
    20 Mar 2009
    7,934
    Thanks Received:
    1,292
    Potters Bar
    Country:
    The foam I use only expands by about 20%, so it's more predicteable :D
    • Thanks Thanks x 1
  14. AdFromEssex
    AdFromEssex
    17 Jan 2012
    20
    Thanks Received:
    Essex
    Country:
    Thanks all!
    • Like Like x 1
  15. Nige F
    Nige F
    28 Jun 2005
    21,206
    Thanks Received:
    1,741
    Country:
    Is that the special stuff that you use with a gun ?
    • Like Like x 1
  16. HERTS P&D
    HERTS P&D
    9 Apr 2010
    13,100
    Thanks Received:
    2,022
    Hertfordshire
    Country:
  17. You're a sick man
    (and that's a compliment (y))
    • Like Like x 1
Loading...
Share This Page
