    Dismiss Notice
drill guarantee
Discussion in 'Tools and Materials' started by BARCUD, 8 Nov 2013.
  1. BARCUD
    BARCUD
    18 Sep 2008
    163
    Thanks Received:
    Gwynedd
    Country:
    Hi, I was looking at a drill driver and noticed that the guarantee is 12 months repair only. Is this normal? I thought most guarantees were around 2 or 3 years.
  2. phatboy
    phatboy
    22 Jan 2012
    2,195
    Thanks Received:
    259
    Jersey
    Country:
    It entirely depends on brand....
  3. Sponsored Links
  4. Astra99
    Astra99
    1 Feb 2011
    902
    Thanks Received:
    144
    Gloucestershire
    Country:
    If you are buying a cheap drill/driver for £15-20, then so long as it works for long enough to do three or four jobs, then fair enough. However, if you have paid a lot more for a "professional" drill/driver, then I would expect at least a 1-year replacement warranty, if not longer.
    In my experience, the cheaper (and sometimes no-so-cheap) drills using Ni-Cd batteries are not, by a long chalk, as efficient or long-lasting as those using the newer Lithium-ion batteries.
    I was buying two cheap drills a year and cussing when the batteries failed to hold their charge. My last purchase, over a year ago was Li-ion, and it's still as good as when new!
    • Thanks Thanks x 2
  5. big-all
    big-all
    12 Jul 2004
    18,991
    Thanks Received:
    1,491
    Surrey
    Country:
    also the batteries will not be covered in general as consumables they may be covered for say 1 year but no more unless they have had a bad problem with a type or design off battery that they have now solved and need to give confidence back
    • Thanks Thanks x 1
  6. Sponsored Links
  7. muggles
    muggles
    28 Oct 2005
    13,343
    Thanks Received:
    3,077
    Daventry
    Country:
    Bosch will give you 3 years on their Pro range and 2 years on the batteries. You get what you pay for...
    • Thanks Thanks x 1
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
