We have just bought a buy to let house which obviously needs some work doing on it. One of the problems to be solved is that in the kitchen, someone has accidentally drilled into the mains cable buried in the wall, coming down from the first floor. This cable supplies a three pin socket on the wall.
They have then ‘hacked out’ the wall and cut out the plastic conduit protector and inserted crimps to reconnect the wires that they had severed. The crimps look those you might use when installing a radio in your car!! The socket was supplying a washing machine, and the wires have all gone black (nearly burned through I think).
Can anyone please suggest an acceptable way of repairing the problem. I would like to avoid having to lift chipboard flooring in the room above as it is the bathroom, and the toilet and basin would both need to come out to do that.
All suggestions would be very welcome! Thanks.
