- Joined
- 29 Nov 2025
- Messages
- 1
- Reaction score
- 0
- Country
Hello everyone,
The other day my girlfriend asked to mount something on the kitchen wall and I had to drill through the tile to mount it. Turns out i drilled through a cable which was powering the induction hob.
The power went off and the circuit breaker went down (the one outside the apartment, not the one inside). I live in a new block of flats in Warsaw. Usually when i mess something with the power inside the flat the breaker inside the apartment goes off - this time it was the one outside the apartment so i know i messed up big time.
Now, because i didn't want to remove the tile (brand new built in kitchen also) i decided I will make a hole from the other side of the wall and find the cable and patch it with a Wago.
Which I did - see attached. The problem is that once I turn the power on and turn on the hob.. the breaker jumps again.
I used a lexman multimeter to check the cable - the beep test and.. no beep
Does this mean the cable is damaged somewhere else too? How could this happen?
Thank you in advance for your inputs.
