Driveway where house is lower than the street
26 May 2010
I have been trying to pick peoples brains about my house which is lower than the street/pavement. I havnt had much luck as of yet.I want to construct a driveway which will be 5.6mx4m.I have put in for planning permission.To run the surface water into the road i would have to raise the drive 1300mm.This would block out light into the front room.I wanted to run the water off the drive towards the house.The drive would be 1.5m away from the house.I have asked people about pea shingle but as i thought they have said its too big an area and would eventually cause problems as ground is clay.No drains to connect to.Nowhere to dig soakaway.Personally hate block paving so dont want permeable paving.
Just thought. Would it be ok to have it open all the way round so water runs off to the sides and the back.Then have 800mm all the way round the sides and 500mm nearest to the house left as soil and plant hedgerows.Would this be adequate drainage
You are not allowed to drain onto the road anyway. Your best option is a loose stone fill onto some form of matrix. e.g. a plastic honeycomb grid. That way you are not altering the existing natural surface drainage.
