Hi there.
I have built a conservatory on my semi detatched house and my neighbour and I share a party wall on the connected side. We have both built conservatorys at the same time.
The party block wall is 9 inch thick and on my side I want to dry line. As it is not an external wall can I just board onto this wall or should I insulated first batten off then board onto the battens?
On the other two walls these are outer concrete block cavity with inner thermalite blocks. Again should I insulate or dot and dab straight onto the blocks?
