Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Which is irrelevant. Doing the one or other can be done when you decide to fix the problem - ie when you have got parts, found the time, etc. In the meantime, having an easy means of isolation means you don't have to (as in the example above) switch off a whole circuit (and have the freezer defrost) or pull the cooker out (and then put it back until you are ready to fix the fault).
