A picture showing more of the meter and consumer unit area would be extremely helpful here.
Where did the earth cable go before the new work was started?The installer said they remembered breaking out the top to accept the earth.
Is it possible that this friend, purposely sabotaged the work, in order to get out of paying?The customer is refusing to pay.
I think this woman is just wanting to get out of paying.
The friend only needs to be competent, I agree with suspicion of power theft.Does this friend have any formal electrical training or qualifications?
Me being suspicious i'd suspect an attempt at power theft gone wrong (by the householder).
It also looks like the plug above that screw is missing but the one agjacent to the neutral is still present.
Unless they're after a second opinion to their own unsure concerns?They can sod off anyway, if there is a problem with any work, the correct procedure is to immediately contact the person responsible for the work and get them to fix it straight away, NOT to ask someone else to look at it.
It means he was intending to connect the earth somewhere different to where it was before. I would have expected the earth to be connected on the side rather than the top.What does that mean
Yes, but i think i would remember intentionally knocking out the plastic of a cut out, presumably hitting a screwdriver with your pliers, when I should not have been dismantling it in the first place, would not you.It means he was intending to connect the earth somewhere different to where it was before. I would have expected the earth to be connected on the side rather than the top.
I'm not going to swear to it but I think the blue arrowed cable entry has been unplugged and looks cleaner than the restWhat does that mean
As already mentioned, that's not automatically the case. Given the prevalence of plastic service pipes these days, it's quite possible for an installation to have no effective earth other than the DNO PME facility. And if this is the case, then little current would flow, but everything "earthed" would be live.If that earth wire is connected to anything at the other end, inserting the fuse into that would cause a severe fault, probably enough to blow the main fuse, and causing arc damage to the fuse holder and those terminals.
It has not been energised like that for 2 days or even 2 minutes.
