Situation bit long I'm affraid but help is needed.
I have an outhouse with fridge freezer/washing machine/tumble dryer and one light.
It has a two way CU fed from the main house CU by a 10mm T&E two fuses one for light and one for the white goods mentioned. It also has hot and cold water fed from the house.
A while ago BG moved my gas meter from inside to outside the main house [Plastic Pipe] but did not connect a new earth to the new gas pipe downstream of the meter feeding boiler and gas cooker.
Can I connect a 10mm earthing cable to CU in the outhouse or run it all the way round the house [very long run] or can I bond it to to the old disgarded steel gas pipe left in place.
All pipes in the house are bonded and bonded and to the inlet water copper pipe.
Billboy
Billboy
