He's not an electrician. He is a lying, cheating charlatan. Kick him into touch NOW. And don't pay him a penny.the electrician seems to think he can get it to work with a 2 gang slave upstairs
Are you sure it was coming from the cables ? More likely it was from the inside of one or more of the dimmers as they burnt out due to incorrect installation.Thanks for your response electrician was here 3 days trying to get it to work ... when the power was put on there was a tiny bit of smoke coming from the two cables
Because he is a con artist.Why is this chap ( so called "electrician" ) taking a neutral to the switch.
Why?Shame really but I'll be getting a single master and single slave to complete my lighting![]()
Thanks for your response electrician was here 3 days trying to get it to work put 2 cables in the load side of the master not sure what they were but when the power was put on there was a tiny bit of smoke coming from the two cables not sure if it's possible to fry the switch through the load side though isn't it protected ? The main question is if the bathroom light will work off the slave am sure the electrician said something about running some cables to it from the master something about a neutral and 3 switch wires are needed ? But won't that turn the bathroom light into a 2way with the master downstairs ? Thanks
You need to disabuse yourself of the notion that the guy you had was an electrician.electrician was here 3 days trying to get it to work
