ECONOMY 7 METER READING HELP TO UNDERSTAND
23 Feb 2014
Surrey
Hello, would someone be so good as to tell me how to read a meter and what their meanings are please.
The meter itself is a Radio Telemeter Series K, the make is Horstmann, type: K222K03.
I know to press the 'display' button, however, i still cant work out all the numbers what they mean!
I am new to this Economy 7 lark and trying to understand and tweak the heating system.
My pressing annoyance is to firstly understand and make sure that the meter is operating correctly.
On viewing the meter as it is: RATE NOW 1: 02070
1st press of 'display' button RATE NOW: 3: 1675 kw
2nd press of 'display' button RATE NOW RED DATE TIME kw
8888 8:8888 kw
TOTAL NO LOAD
3rd press of 'display' button TIME (i figured this one out) was correct
4th press of 'display' button DATE also correct
I am concerned as have received 1st winter bill as recently moved in., and it seems extremely high. Am curious as to what the 2nd display means!
Furthermore, i understand about the input/output on the storage heaters, however, all 3 of them seems to be at different levels of heating coming out, even though all set the same, or different settings.
Anyone i would be grateful for someone to explain these settings.
Thankyou.
Thanks PrenticeBoy, however, my display is not quite like that one you posted the link to, but thanks for your help.
My order of display sequence is as i have posted, tho, i would have to press no 5 display to get back to the beginning.
Anyone else can give me another explanation of my display, will be appreciated.
1st display is the power you've used during peak times.
2nd display is the power you've used during off peak times.
3rd display just shows the meter is working properly.
4th and 5th displays you've already sussed out.
