Hi Owain, Where did you get the dates from?
Not for long ... 'competent persons' should die with Amd 3... but at least it clarifies where competent person comes from it is the BS 7671: 2008 definition.
Clearly crime in Scotland must be worse than Wales with so many provisions for entry systems.
However note that the section referred to earlier, regarding electrical inspections is in Part 3 and therefore applies only to private rented housing. No such requirement is being made under Part 2 for social (Housing Association or Local Authority) housing.Possibly, but Scotland has much larger numbers of tenements / flatted properties. For council houses only:
Total dwellings....317,572
House................143,649
All Flats..............173,923
High rise flat.........18,622
Tenement.........60,418
Four in a block.....60,038
Other flat....34,845
