Hi guys
Sorry know this isn't alarm related but thought this was the closest forum that might be able to help.
We have a set of electric gates across our drive that have safety IR beams either side of them. Recently the ones in front of the gate have been playing up in the mornings and it would appear it's because the sun is hitting the beam and washing it out. So once the gates have opened they will not shut as they think there is something in the way. I've tried adjusting the angle of units slightly but can't find a reliable position, nor does trying to shield the units themselves seem to work so can anyone recommend an alternative unit that would be a direct replacement but have a stronger beam?
These are the ones we currently have
http://www.ebay.co.uk/itm/140402566...IT&clk_rvr_id=869713148022&afsrc=1&rmvSB=true
Would these possibly be a better alternative
http://www.amazon.co.uk/cameras/dp/B008X0VPVW/ref=cm_cd_ql_qh_dp_t
Would the double beam be better than the current single or is it likely to cause more issues? Also are IR sensors all pretty much the same wiring wise or do specific makes have their own confguration. ie are these likely to be a direct swap
