Pardon my ignorance but I am a bit of a novice when it comes to electrics and need some help!!!!
here it goes...I recently moved into a new house which has a utility room to house my fridge, washing machine and tumble dryer. To my annoyance there is only one single socket. Naturally, I plugged in a 13A extension to power all three appliances and the fuse blew on the extension and has done several times since if all appliances are running at the same time
I have done some research and found that you can buy single to triple socket converters (i.e. 1 gang to 3 gang socket) where you can connect wires from single socket to make a triple socket that screws in the back box of the single socket. This sounds great but noticed that they use a 13A fuse. Surely if all appliances are plugged in to this converter (in seperate sockets) the fuse will still blow on the converter? so what is the point? and why do they have a fuse when 2 gang converters do not? isnt this just another extension but wall mounted???????
I need some help fast
