So... I found Plumber's Mait difficult to use last time, as far as I can remember (not very far at my age, sadly), but I still have the tub. Consistency seemed a bit stiff, so it was hard to spread I think...?
Anyway, when putting it (eg) between the top of the waste unit and the basin, do you leave the supplied washer out altogether, or use both?
Same underneath - would you put some both sides of the rubber washer, or just one?
I take a squashball sized lump out the tub. Roll it between palms as if you were rolling dough balls. Do this until the ball warms up and becomes pliable.
Then roll it out to make a 10mm sausage.
Wrap this around the upturned waste neck, so that it goes around the flared part but doesn't cover the slots for the overflow.
Use your finger to gently push the sausage against the radius of the flared end. No washer!
Turn waste upright and place into basin hole, make sure you align slots with overflow channel, moulded into basin.
Push down evenly and firmly so that mait starts to squeeze out around flared end.
Make another sausage and, from underneath basin, wrap this around neck of waste, up against basin throat, covering the anular gap.
Again gently push sausage into place so that it haunches between basin and waste.
Slip bottom washer up neck of waste, against putty.
Spin on the back nut and tighten as much as you can by hand, whilst holding a screwdriver wedged into slot in waste and against moulded channel to prevent waste turning and blocking slots from channel.
Tighten a bit more with basin wrench/grips.
Putty continues to ooze out.
Tighten but not over tight!
It's a learned thing.
Use fingers to remove excess from below and a small flat bladed screwdriver/screw/nail to remove excess from around the flared end, in the basin.
Roll the bits into one ball and place back in the pot for next time.
Did 6 of these replacements, in one house, last week. Took me longer to remove residue silicone which was pumped in everywhere, than it did to fit with plumbers mait.
All tested and leak free at first attempt.
