Im not sure if this has been covered nor am i sure what your boiler can do nor what system design it has, ie s plan or whatever, however in general:
the UK market has become driven by the idea that TRVs are the way for best efficiency
but its not always true
But that is contrary to the science, the most efficient way to use a boiler is to have the heating flow temperature at the lowest possible necessary to reach the target temperature in relation to the external temperature.
condensing boilers only start condensing at 54 deg or below, and the lower the return temp the more efficient
also the lower the radiator temperature the more efficient the system
So the best systems are designed to have separate hot water flow temps to heating temps.
its best to have the hot water temp at max boiler temp say 80 deg and the heating temp at the lowest possible and set by weather compensation
having TRVs actually strangles the efficiency of the system and the boiler is producing hot water to heat the house but its not being transferred to the house but returning to the boiler.
have a look at heat geeks and or urban plumber on this
According to HeatGeek, it's best to maintain a constant flow of heat at a low temperature to maximize heat pump or boiler efficiency. This can be achieved by using a setback temperature for unused rooms and adjusting the flow temperature of the boiler.
Explanation
- Setback temperature
Use a slightly lower temperature for unused rooms so that flow continues. This can help prevent the other radiators from having to work harder.
- Flow temperature
Lowering the boiler temperature is the best way to reduce heating costs. However, setting the flow temperature too low can make the property too cold.
- Weather compensation
Use weather compensation functionality to maintain the temperature in the building. This can help prevent rooms from overheating.
- Modulating boilers
Use a modulating boiler with burner-linked pump control to adjust the pump speed based on the heat input. This can help ensure the correct flow rate.
- Condensing boilers
Use a condensing boiler to cool the combustion gases to below 57°C. This allows the water vapor to recondense back into liquid water, which releases hea
Explore expert-written heat pump articles, guides, and news from Heat Geek. Learn about low-carbon heating, grants, installs, and homeowner FAQs across the UK.
www.heatgeek.com
