Expanding foam around 110mm soil pipe
13 Feb 2025
Got a toilet which has 110mm soil pipe going outside the exterior wall. The hole on the inner wall is oversized and needs filling. Can I stick expanding foam into this hole? Does expanding foam degrade the soil pipe wall?
Expanding foam then a collar or expanding foam then finish with some of that cement in a tube
As above, the expanding foam will not damage the soil pipe. In theory, it will not actually adhere with the plastic but it will adhere to the brickwork. Remove the dust and then mist the area with water- it aids adhesion and speeds up the curing time.
Cut away any excess foam and use your fingernail to enable you to back fill with an interior filler- you said the hole is inside.
