extending ladders
Avoid the ones with square rungs or round rungs. They are uncomfortable to work on for any length of time. Get 'D' rungs.
Also, avoid ones where the three sections are all the same width...
207-5813_PI_TPS584676
Because they take up more space in storage, and you want the base to be as wide as possible for stability. The ones where each section 'nests' inside the next section are best, easier to carry, too...
Lyte or TB Davies would be good brands to look at. Make sure it says EN131, or Class 1.
Don't buy Class 3 (AKA 'domestic') ladders, even for home use, they are allowed to make them with weaker stiles and have a shorter overlap between sections when extended, which makes them bouncy when going up or down.
This is all great advice and just what I need.
Thanks everybody
my goose
Thanks again
So, I am going to head for Jewsons and Screwfix.
The highest point of our house is the Chimney about 30 ft high
I am going to look for a light aluminium ladder.EN131, or Class 1.
D Rungs not square or round rungs
Not ones where the three sections are all the same width
Look for Lyte or TB Davies
Each section nests inside next one
Base as wide as possible for stability
Have I missed anything?
Is there anything else?
Thanks again
mygoose
To reach 30 feet you need a 40' ladder.
Check with the supplier that the ladder's real height is what it says on the tin.
A lot of sectional ladders "forget" to allow for the overlap .
If you have never been up a 30 foot ladder good luck
You wouldnt catch me going up a 30'0 ladder :eek:
Trees and ladders not a good mix!
Just remove one of the extensions if you dont need it.
30’ is bloody high, and youll need muscles like Popeye to extend the ladders so far.
When I were a lad.....my dad would hold the base ladder firmly, and pretty close to vertical. I’d then shin up the thing, pushing the extension as I went. Worked too!
John :)
Is this 3 10ft sections? Is this what I said OK?
Thanks again
Thanks again
mygoose
Does anyone know an online supplier of the extending ladder with the features you all advised? I canot find one.
About 30 feet
Lyte or TB Davies
Very Light aluminium ladder. EN131, or Class 1.
Thanks again
mygoose
Thanks.
I want to buy one not hire.
I don't know anything about them and I need some help because the trouble is you often don't know you've got the wrong thing until you've bought it.
mygoose
I have a very large and very heavy industrial grade double extension, it is long enough to easily reach the apex of our end wall. I can just about manage one section of it on my own, as a double it needs two. It is so very heavy, that it was near impossible to raise the top section when leaning against a wall, so I bolted a set of wheels to the top end to make it roll up a wall - much easier than fighting the wall surface when raising an heavy ladder. I also have a light- weight single ladder, which is just long enough to reach the up- stairs window sills comfortably. Using hooks and ropes, I was able to redo the soffits, fascias and gutters a few years ago, mostly from the long ladder.
I have a tall pair of steps, which make painting our slightly higher than normal ceilings easier to paint, then couple of pairs of 7 & 8 tread steps, then finally a three tread, which is good for reaching high shelves.
You can never have too many steps and ladders..
I have just noticed the overnight wind has managed to snap a small tree at the far end of my back garden - anyone need any fire wood?
