Hi
I run a small home printing business and use a heat press to print onto T Shirts. All the printing is currently done in the dining room and I want to do it in the outhouse. Sadly there is no power in there and I dont use it very often. But I want to clear the dining room of the Computer, monitor printer and the heat press to give the kids a room to play in.
So I want to run an extension lead from the dining room to the outhouse whenever I do the printing. Can I do this with the appliances i have? The computer and printers should be fine, but its the heat press which worries me.
It says 9.6a on the side and in the book says it needs to plug into a 15a socket. It draws 2200w.
I will not have the press and computer on at the same time but when pressing will use a desk lamp and the press at the same time.
Is an extension lead ok to use for this? If so do I need one with RCD or surge protection etc??? I am complete novice with electrics, but our downstairs ring is RCD'd in the fuse board if that helps. I've also run the heat press off the same double plug as a plasma TV before.
thanks
thanks
