It is Scotland which has warrants - E&W do not.Is a warrant also needed in Scotland (where I live)?
They will vary a little in formatting, but they should all contain the same information.Are these documents on a standard template so you can check it looks correct or does the electrician create his own version of these and they might look different depending on the electrician?
The extent to which "no-one" does or does not bother might not apply when registering a property to be rented out - the council may very well be 100% bothered about work which needed a warrant not having one.I asked about building warrants & other paperwork for CU replacements a while ago; the answer seems to be that yes in principle you do need a warrant, but no-one bothers.
Have you bought a flat from a numpty who put down laminate flooring without thinking about wiring needs first?that might involve ripping up new laminate flooring.
They don't; they can't.I tested the bathroom 1 out by putting the shower on and closing the window. The fan didn't seem to make that much difference to condensation levels.
